Hi Houdini peeps,
i have been playing around with Houdini Indie 15.5.480 and noticed that the sss does not work or its behaviour has changed. Has anyone else noticed a big difference.
i'm on a mac with El Capitan.
i also uploaded a very simple file.
thanks Paul.
Houdini Indie sss issue
4074 5 1- Paul Jones
- 3 posts
- mawi
- 242 posts
- Paul Jones
- 3 posts
- Paul Jones
- 3 posts
- OmarSantos
- 1 posts
Hello! I have a problem as well while I try to render my sss passes in houdini 15.5 . They can be visualized in the color pass, but they are not in the sss passes. I tried to use the skin shader,The material built shader, i tried to build my own sss shader and the same happened to all of them. I can't seem to find any solution. By the moment i can't upgrade to 15.5.489. Is there any way to solve this issue ?
- sachiman
- 38 posts
OmarSantos
you just have to make it by yourself add “physical sss” and connect it to a parameter and call it Ce that's it
