Hi
When adding an integer or float to a parameter interface is it possible to make it display a value?
For example I have a null node and I add a float (or an integer) parameter to it, can I say, somehow, display the result of 50+23?
Or even better, display the result of the sum of these two channels?
Adding a counter to a parameter interface
2525 2 1- SteN
- 55 posts
- neil_math_comp
- 1743 posts
You can enter an expression into the channel and set it to display as a value instead of the expression by clicking on the parameter name. A fancier trick is to add a Label parameter, hide the main label for it, and in the first entry in the big stack of text boxes in the Parameter Interface dialog (all but the first are greyed out by default), you can enter an expression in backticks, e.g. `ch(“asdf0”)+ch(“asdf1”)` or `details(“inner_node_0”,“string_attrib_name”)`.
That lets you display informative messages, particularly if you're making assets that may have some error checking, and you want to notify the user what happened when things go wrong. I used it for my equation solver asset on Orbolt to notify what it's treating as unknowns to solve for and what it couldn't parse correctly.
- SteN
- 55 posts
