Volume color ramp distance from center to boundary
   3841   3   0
I'm sure this has been covered and I'm sure it's trivial but I'm not able to find the links. I'd like build a color ramp based on the distance from the center of a volume to it's boundary, and transfer that to points. Tips?
You can do a volume sample to get each points distance in relation to an SDF's surface. This value is a float and you can plug it into a ramp to colour your points. I've attached a a scene file which has it both in VOP and VEX format. Hope this helps!
colorPtsByDepth.hipnc (316.9 KB)
Super helpful file, thanks! I was confused for a moment with the Bind Outputs using “parm” but I see that it's just to see your VOP values in the spreadsheet
Edited by AndyW - Aug. 24, 2016 09:53:36
Ah yes, should have annotated!
