How to persist an Attribute in Geometry Detail
   1904   1   0
I have a text file representing a regression tree for some machine learning evaluation I'm doing on the GPU.
I'm using a python node to load the text file data, then calling the following to add a detail to the geometry.
left_attrib = geo.addAttrib(hou.attribType.Global, "left", leftArray)
The problem is that I have to load the text file and call addAttrib every frame for it to persist, costing very precious milliseconds. Am I approaching this wrong? I just need some way to take my data and present it to next node (This OpenCL node: https://www.sidefx.com/forum/topic/44718/). [sidefx.com]
Ideally I'd like to only load the txt file once, maybe if frame is 1 or with some reload button.
I'd really appreciate some help with this, thanks.
I think with attributes you may need to check if they exists before you add them.
node = hou.pwd()
geo = node.geometry()
# Add code to modify contents of geo.
# Use drop down menu to select examples.
curAttrib = geo.findGlobalAttrib("my_detail")
if curAttrib == None:
# Time to create attribute.
s = 1.0
curAttrib = geo.addAttrib(hou.attribType.Global, "my_detail", s)
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
