How it could make a cutoff with volume for an CopyOp?
I would like delete complete instances of source object that it position be outside (or inside) from that volume.
Cutoff for CopyOp?
2818 4 1- Unaided
- 49 posts
- pwquint
- 53 posts
The copy op works by copying an object to points. The best way to approach what you want is to delete the points that are outside the volume. You can use an attribute from volume node to create an attribute on the points that tells you whether they are in the volume, use a point wrangle or group sop to group the ones outside the volume, and then delete that group.
Peter Quint
- Unaided
- 49 posts
- Unaided
- 49 posts
I want to share my personal exercise building a cutoff for a CopySOP and a bit more. It's a basic thing for anybody Houdini guru's. Anyway I have been done a tutorial about it. I hope could be useful for some beginner Houdini user.
http://vimeo.com/albertogz/houdinicopiescutoff [vimeo.com]
PS. My apologizes for my bad english.
