Hey there,
Can anyone tell me how (if possible at all) would one access Houdini “scene material”?
The default grey mat. every imported object inherits seems to be a very elusive feature. Am I missing something?
As always, googled it before posting, but nothing relevant surfaced as far as I was able to figure.
Scene material
5304 7 0-
- anon_user_89151269
- 1755 posts
- anon_user_37409885
- 4189 posts
- 1755 posts
OK, I was hoping to be able to modify it in Houdini interface and save it as default instead of setting env. var.
But since it seems that I have to do this, I might as well spread myself thin here and learn how to deal with Houdini env var.
So, I've searched in my file manager for “defaultshader” and it returned one single file with no extention in \houdini\config\Dialogs\VOP\ no .vfl or .vex with that name.
What am I missing?
Also, the help on env. var. is pretty sketchy http://www.sidefx.com/docs/houdini/basics/config_env#setting-environment-variables [www.sidefx.com]
What am I missing?
Edited by anon_user_89151269 - June 12, 2017 06:31:25
- 4189 posts
- malexander
- 5266 posts
- 1755 posts
Thanks for the info, that might come in handy some time, but I'm not looking to just change how objects look in vp. I'd like all the objects that I create or import to inherit a specific/custom material. It's not awfully inconvenient to select them and assign the mat I want afterwards, it's just that I was hoping to able to get away with not doing this extra step.
BTW, my expectation comes from, you guessed it, where in every scene there's a “scene material” (named exactly like this IIRC) which gets assigned to every new object you create/import (object duplication being an exception). This mat has a simple phong shader connected to the surface input, so if this feature ever gets into H, principled, classic, w/e will the trend be at that time will be just dandy.
- malexander
- 5266 posts
- 1755 posts
Vop/defaultshader’
