Attribute transfer with persistant effect
   4705   3   0
For example i want to transfer the Cd attribute, but want the Cd to keep the color value once it's been transfer , so if i then move the source object away, the target object still keep the value of the Cd.
How can i do this ?
After doing the transfer you could lock the node ( ctrl + left click ) that now has the transfered attribute.
Then you could remove the source from which the transfer was made.
In the hip - sphere1 and pointwrangle1 can now be removed.
Keep Attribute Transfered After Source Removed.hiplc (51.6 KB)
Def go with the solver sop. Inside, add the color of the previous frame to the color at the current frame.
