Hello.
How do i connect subnetwork inputs from my nodes within the subnetwork?
I have a polyextrude node and a few bevels which are connected to a switch node.
I would like to connect these nodes to the subnetwork input#1-#4 labels. Bonus question, can i make sliders for each value of each connection?
Connect subnetwork inputs 1-4.
2471 1 1- gasen
- 5 posts
- Rebus B
- 80 posts
Not clear from your question… Are you asking where the Sub-Network Inputs #1-4 get their data? They are simply sourced from the four network connections on the top the subnet node, anything connected to the dots on top of the subnet node are piped into the subnet via the 4 inputs.
To make a slider to pick from multiple nodes feeding a single input connect them to a switch and add an integer parameter (per input to control) to the subnet node (via Edit Parameter Interface… under the gear next to the node name in the parameter editor panel.) Then reference the new parameter in the switch node feeding the subnet input.
like so:
like so:
Edited by Rebus B - Sept. 18, 2018 18:12:13
