Rendering points/particles
   2674   4   0
Hello Forum:
I'm using NC Apprentice version. This is newbie question. How do I get the particles/points to render as particles (like in the scence view) and not large spheres?
I have attached screen shots and my project file.
I was following this tutorial https://www.youtube.com/watch?v=udTFwjiRKSk [www.youtube.com]
Thank you in advance!
Edited by catnap - Jan. 6, 2019 21:14:49
Scence view.JPG (147.2 KB)
Render view.JPG (52.4 KB)
shockwave.hipnc (1.1 MB)
Hello, drop a point node set the Attribute to Scale(pscale) and change the VEXpression to value and then adjust the size! The particles are rendered in your screenshot their size is just very big so try a small value to get am more particle like look!
Hope this helps
Hi Maschinenfabrik,
Thank you for your suggestion.
Where in hierarchy should the point node go? inside the torus geometry?
Thank you!!
point node.JPG (37.9 KB)
should be ok to put it at the very bottom after the popnet
Thanks Maschinenfabrik!
It worked!
