I admit that coding, whether it be MEL or Hscript has always been my weakest area. The problem is getting syntax right. I guess I am a justt a visual kind of guy.
Anyway, I thought I had done right on this yet I am getting the red arrow.
I appeand a PointSOP to a SOP net in order to randomize the postion of vertices.
In Piont tab I use following expression. I relace $TX or ($TY, or $TZ) with
fit(rand($P),0,1,-.1,.1) in order to add random value to a point position on a per point basis. I thought this is correct syntax, but I am getting a red arrow. So obvious the syntax is incorrext.
I also tried the ‘mel’ approach.
$TX = $TX + fit(rand($P),0,1,-.1,.1) $TY = $TY + fit(rand($P),0,1,-.1,.1)
$TZ = $TZ + fit(rand($P),0,1,-.1,.1)
So what is the correct syntax for randomising point position in pointSOP?
Thank you kindly
Dave Rindner
Point SOP with fit()
5164 3 1- Dave_ah
- 436 posts
- RickW
- 141 posts
- EigenAlex
- 639 posts
- Dave_ah
- 436 posts
I thought it might be my syntax. All I was missing is T after my $P
I deployed Houdini at work as geometry server for Maya and Cinema4D.
I export sngle frame geo as OBJ, and animated sequences as either OBJ seqs or RealFlow .bin meshes that are read into Maya or C4D using NextLimit's RF import.
I am looking for a freelance C++ programmer knowledgable with both Houdini and Maya SDK to write a bgeo FileIn node for Maya, that works same as FileSOP.
Dave Rindner
Dave Rindner
