Hello guys.
Just wanted to check with others.
Going from H17.0.416 to H17.0.459 and any above versions, including H17.5 we do see huge speed regression in reading and working with Alembic files.
Loading same Alembic takes cca 4-10x longer, dropping and connecting empty nodes (atwrangle, nulls) invokes cooking of alembic and takes up to 150s to drop and connect null nodes.
This is not happening in any version bellow H17.0.416
Setting alembic to load as unpacked will fix the slow downs, but we cant render unpacked alembics in our pipeline.
this whole thing forced us to revert back to H16.0
Anyone else experiencing this? alembic im testing it on is nothing huge (2.700 packed alembics)
Alembic speed regression since H17.0.416-459
2788 10 2- martinkindl83
- 260 posts
- jsmack
- 7808 posts
I haven't noticed anything out of the ordinary. I see the occasional corruption of the gpu vertex ordering, but I don't know what version I started seeing that.
I don't really work with alembics that enormous though. Usually only a few shapes max, (mostly characters). The occasional vehicle model may have a few hundred pieces though.
Are you seeing issue with playback of animated alembics, or just the initial load of the file?
- martinkindl83
- 260 posts
- AdamJ
- 268 posts
yep experienced same thing (submitted bug about it). One strange note.. if you copy/read abc file off a local drive then it's back to being scrubble. Reading off network drive it can take up to a minute to refresh. At first I thought it was our network but there's a definite difference between houdini builds.
Edited by AdamJ - April 23, 2019 10:27:50
- keyframe
- 1532 posts
- derrick
- 329 posts
- martinkindl83
- 260 posts
- derrick
- 329 posts
- derrick
- 329 posts
- martinkindl83
- 260 posts
- martinkindl83
- 260 posts
