Hello. I am trying to use Pixar's Renderman (23.1) with Houdini 18 indie and when I try to render I get the following error.
File “<stdin>”, line 1, in <module>
File “C:/Program Files/Pixar/RenderManForHoudini-23.1/18.0/python2.7libs\callback.py”, line 95, in dumpRib
node.render()
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.388/houdini/python2.7libs\houpythonportion\ui.py”, line 927, in decorator
return func(*args, **kwargs)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.388/houdini/python2.7libs\hou.py”, line 56815, in render
return _hou.RopNode_render(*args, **kwargs)
OperationFailed: The attempted operation failed.
Error: Indie does not support generating disk files.
No command specified for rendering
Does anyone have any idea why this is happening (just in case it has something to do with Houdini)? Thank you in advance.
Error "Indie does not support generating disk files"
1523 4 0- ventralstreams
- 34 posts
- Enivob
- 2551 posts
I think I experienced that in H17.5. Try using a different output driver, like old-school rib generation.
I tried to verify your error in H18 and I could no longer find that output driver option on the Renderman /out/ROP. It looks like it may be fixed in H18. Renderman 23 also works with LOPs.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- ventralstreams
- 34 posts
- ventralstreams
- 34 posts
- Alexandre_Quintana
- 9 posts
