I've been a Fedora Core 5 user until I decided (my bad) to upgrade it to FC6 for some reasons …. and this went to a 4 long useless days… trying to get the system back up and running … and trying at last to reinstall with not much success… apparently FC5 wont run as good as it was before on my thinkpad ..
to make the story short… I'm now on Ubuntu 6.10.
system apprently works fine.. and my really first application I install right after the ATI drivers is Houdini …
it works… but no matter how I do exit the program (File>quit, close button, alt+q) it crashes Gnome session..
following is the debug trace by Gnome
Memory status: size: 40546304 vsize: 0 resident: 40546304 share: 0 rss: 18202624 rss_rlim: 0
CPU usage: start_time: 1173227045 rtime: 0 utime: 425 stime: 0 cutime:394 cstime: 0 timeout: 31 it_real_value: 0 frequency: 0
Backtrace was generated from ‘/usr/bin/gnome-panel’
(no debugging symbols found)
Using host libthread_db library “/lib/tls/i686/cmov/libthread_db.so.1”.
0xffffe410 in __kernel_vsyscall ()
#0 0xffffe410 in __kernel_vsyscall ()
#1 0xb75f0323 in __waitpid_nocancel ()
from /lib/tls/i686/cmov/libpthread.so.0
#2 0xb7ee81b6 in gnome_gtk_module_info_get () from /usr/lib/libgnomeui-2.so.0
#3 <signal handler called>
#4 0xffffe410 in __kernel_vsyscall ()
#5 0xb75727cb in poll () from /lib/tls/i686/cmov/libc.so.6
#6 0xb76ee813 in g_main_context_check () from /usr/lib/libglib-2.0.so.0
#7 0xb76eeb89 in g_main_loop_run () from /usr/lib/libglib-2.0.so.0
#8 0xb7aed574 in gtk_main () from /usr/lib/libgtk-x11-2.0.so.0
#9 0x08061d8c in main ()
Thread 1 (Thread -1225550160 (LWP 14120)):
No symbol table info available.
any are really welcome.
cheers.
Houdini 8.1.897 and Ubuntu 6.10
5359 6 0- VisualCortexLab
- 509 posts
- Joe
- 483 posts
That's a totally normal GNOME stack trace, so what I think is happening is that X is actually crashing.
I seem to remember having troubles with X crashing when I first installed the ATI drivers, but I think I upgraded and solved my problems. Make sure you're right up to date with the version available on ATI.com.
- VisualCortexLab
- 509 posts
HI
yeah i was using the standard “repositories” drivers (which was old 8.28.8) and now manually installed the latest 8.34 drivers… but doesnt really fixed it.
after a system upgrade (prior to drivers install) the gnome wasnt crashing anymore … but what I had (and still have) as a problem.. is that if I quit the application Houdini cant popup the “save before exit” popup window.
I guess ther's a problem with X maybe?
any ubuntu users here that have same problem and luckly a workaround?
cheers
cheers
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
- VisualCortexLab
- 509 posts
….now that i think more about it… couldnt be a “sound” problem?… i remember about reading about sound problems with Houdini and Linux before.. never had those actually.. but now can be there the problem.
ps.. damn me and when i decided to upgrade my Fedora… it was so great… and dont ask me -why- i wanted to upgrade…
JcN
- Pagefan
- 519 posts
- VisualCortexLab
- 509 posts
I'll check it out
… but i guess i wont find more Houdinier than here … and this sounds like a Houdini problem ..(or anyway .. Houdini with Ubuntu)..
I'll keep posted.
I'll keep posted.
JcN
- VisualCortexLab
- 509 posts
ok I found the problem.. ehehe.. seems that I'm having the same exact problem I had with Fedora Core 5, I need to install the GCC3.2 version because the GCC3.4 is much more unstable… and seems on this ubuntu is the same.
GCC3.2 have no problem at all.
cheers
cheers
JcN
