Hi there,
every time I do/did a "black boxed asset" and I have a file cache or a Dop I/O I can't execute the save cache. Why?
Houdini returns that error and I can't understand how to fix it. If I used HDA works fine.
return _hou.node(path)
hou.PermissionError: You don't have permissions to access that node in a compiled HDA.
thanks
Mat
hou.PermissionError - how to fix it?
1467 2 1- MatEvil
- 147 posts
- danielcharles
- 1 posts
- MatEvil
- 147 posts
danielcharles
This also happens if you are trying to write a file, but your path is a folder.
This can happen easily by mistake.
To defend against that, use:
import os
Thanks this error is with the filecache Sops and inside the geo path, I write a simple expression like "$HIP/geo/$OS/v001/$OS.$F4.bgeo.sc".
always that problem with that sops:
File Cache
File
DOP I/O
Why if I used the HDA it's working and when I create a black-box doesn't works?
Matteo
