I'm getting this error with a scene set up in 19.5.303 when I run it with a different Houdini version on another PC. In my case 19.5.368. It's a Vellum sim and the responsible node for the error seems to be the Vellum constraint one when set to pressure. The cloth constraint seems to work just fine. Both PC seem to up to date concerning the GPU driver.
Anybody else running into this problem? Any way to fix this? Bit annoying since I prepared this scene for my students who are running into the same problem now. : (
Cheers
Tom
OpenCL Exception: clSetKernelArg (-49)
1911 8 2- Tom Mangold
- 96 posts
- Tom Mangold
- 96 posts
- Andr
- 900 posts
- Tom Mangold
- 96 posts
- Tom Mangold
- 96 posts
- Gumbyslacker
- 2 posts
What GPU driver are you using? I started getting a ton of OpenCL errors on 19.5.368 when I updated to the latest Nvidia Game Ready driver (522.25) (just doing simple cloth sims). I rolled back to 517.48 and everything is working again. There are reports about that driver causing problems with other 3D software as well. They must have done something with their OpenCL implementation. Not sure if the same problem is on the Studio driver or not.
- Tom Mangold
- 96 posts
- Tom Mangold
- 96 posts
- Gumbyslacker
- 2 posts
