I created a python script which converts a VDB volume into a numpy array (See file). How can I reverse this process: How to create a VDB from a numpy array?
Thanks for any advice
Convert Numpy Array to VDB
1084 2 0- AvanDAM
- 1 posts
- jbudsberg
- 92 posts
Sorry I'm late on the reply! But heads up there are VDB Python bindings (which do interface with Numpy).
import openvdb as vdb import numpy filename = '/work/stanford/Dragon.obj' print 'reading: %s' % filename points = [] triangles = [] quads = [] f = open(filename, 'r') lines = f.readlines() for line in lines: t = line.split() if t[0] == 'v': # vertex points.append( [ float(t[1]), float(t[2]), float(t[3]) ] ) elif t[0] == 'f': if len(t) == 4: # triangle triangles.append( [ int(t[1])-1, int(t[2])-1, int(t[3])-1 ] ) elif len(t) == 5: # quad quads.append( [ int(t[1])-1, int(t[2])-1, int(t[3])-1, int(t[4])-1 ] ) np_points = numpy.ndarray((len(points), 3), dtype=float) np_triangles = numpy.ndarray((len(triangles), 3), dtype=int) np_quads = numpy.ndarray((len(quads), 4), dtype=int) for i in range(0, len(points)): np_points[i] = points[i] for i in range(0, len(triangles)): np_triangles[i] = triangles[i] for i in range(0, len(quads)): np_quads[i] = quads[i] xform = vdb.createLinearTransform(voxelSize=0.5) grid = vdb.FloatGrid.createLevelSetFromPolygons(np_points, np_triangles, np_quads, transform=xform) grid.name = 'surface' print 'name:', grid.name, ' class:', grid.gridClass, ' background value:', grid.background, ' voxel size:', grid.transform.voxelSize()[0], ' active voxels:', grid.activeVoxelCount() vdb.write('/tmp/foo.vdb', grid)
- jbudsberg
- 92 posts
