create a surface from line with copy to point and skin
1113 6 1- MatEvil
- 147 posts
I have a question about the creation of a surface. I have a copy to point and line, so I want to create a planar surface (so no thickness) so I used the skin sops, but I have also the creation surface inside.
The source of Copy to the changes point is not regular in the time but changes a number of points frame by frame.
Any idea for creating a surface from the line without the intersection?
I attached the images for a better description and the file
Thanks and good Friday
Matteo
ps.: I try also to create a group for deleting it, but not a good solution
Matteo
- Aizatulin
- 479 posts
- MatEvil
- 147 posts
- MatEvil
- 147 posts
Aizatulin
you can try boolean instead of intersection analysis and extract the boundary shape. With this shape you can sort the primitives.
I try but I don't understand why in some of my frames I am missing the geometry, I try to work on the vex for forcing it but it didn't work better... works on some frames and not on others...
any idea?
- Aizatulin
- 479 posts
- MatEvil
- 147 posts
- Aizatulin
- 479 posts
