Pyro volume issue
574 2 1- richard1771
- 3 posts
- Enivob
- 2539 posts
- richard1771
- 3 posts
EnivobThanks for your answer. It seems that the density is right (I've pushed it in simulation), but fire voxels are still look blocks at the small density value. I found a possible solution, but I'm not sure is it right.
Blocks can be the results of pushing the density too high in the shader. Try pushing density at the simulation level instead.
So, The flame and density sources have been animated to spawn it on some frames (scr.1). Also, changed the flame intensity scale on the Karma pyroshader to 10 (scr.2) and it became blocks. To avoid it I added pyropostprocess and everything became okay.
