Hi - is it possible to use a custom copy of the RenderPropertiesKA.json config file to set default values for the Solaris viewport Display Options for Karma?
From what I can tell the copy of that file in the Houdini install has all the types, values, ranges for the various karma:global:* parameters that are set by the user via the Display Options dialog.
I'm aiming to set some studio wide defaults for those settings, but they don't seem to be covered by the hou.GeometryViewportSettings() methods so am looking for a config file.
Copying the RenderPropertiesKA.json file to somewhere on the HOUDINI_PATH then editing it hasn't worked in my tests, but I may just be putting it in the wrong place.
Does any one know if this should be possible, or whether there is another better way to go about this?
cheers
Custom RenderPropertiesKA.json
242 0 0- Ben Toogood Aardman
- 52 posts
