Frame Selection after loading items from file
   286   1   1
I have python panel with some presets I'm loading from file into the obj context. I then created a callback function to frame the loaded nodes in the network editor. The call back function runs but the network editor doesn't frame the selected nodes for some reason.
Here's my code:
def read_template(template_file):
    root = hou.node("/obj")
    def zoom_selected(node, event_type, **kwargs):
        print(kwargs) # just to check function is being called
        hou.ui.paneTabOfType(hou.panetabType.NetworkEditor).frameSelection()
        root.removeEventCallback((hou.nodeEventType.SelectionChanged, hou.nodeEventType.ChildCreated), zoom_selected)
    root.addEventCallback((hou.nodeEventType.SelectionChanged, hou.nodeEventType.ChildCreated), zoom_selected)
    root.loadItemsFromFile(template_file)
    return 0
Both the print and remove callback statements are called and work, though frameSelection doesn't do anything.
Appreciate any pointers!
Edited by rafaels - March 6, 2024 08:38:42
Toronto - ON
Problem solved with a timer that offsets the home to selection by a few milliseconds... feels a bit dirty, but it works!
Toronto - ON
