I have this scene that when I play the simulation the attributeWrangler19 within the dopnet > sopSolver I want it to keep it's point deform. Instead it moves; I know in this wrangler I'm applying the variable two to the point position @P so because it's within a SOPSolver it will move but what I want it to do is keep its position but just deform based on the parameters I set in this wrangler ?
I've tried applying it to the fiberstiffness attribute and removing the @P += two.y but that doesn't fix this issue either. As well, the back of the mesh when simulating collapses within itself and the back points of the mesh are not effected by the point deform parameters ?
Static Point Deform for Simulated FEM Mesh ?
130 0 1- _Christopher_
- 768 posts
