I have a scene where there`s a pipe breaking in the middle, after breaking it shakes like a trampolim, so far so good.
The thing is when I render it the motion blur renders all crazy with some spikes appearing em some frames.
Anyone know what could be the cause of this?
Motion blur spikes
11794 16 1-
- mzigaib
- 996 posts
- Siavash Tehrani
- 732 posts
- keyframe
- 1533 posts
- mzigaib
- 996 posts
I think you might be right about the points changing.
In fact my points counts change because I use a switch node to change the whole pipe to the broken one.
But how to solve this? Is there a way for me to keep my switch and correct the motion blur as well?
I am posting my render to show the anomaly that I am having. You can see the problem better on the alpha.
It´s a Mill that I am breaking, I did some parts of the ring to fall with DOPS that is doing motion blur fine, the problem is with my broken pipes, since my brake animation doesn't generate the ‘v’ attribute by itself I tried to use the trail node with the compute velocity turned on.
Maybe there's a better way to generate the ‘v’ attribute.
- mzigaib
- 996 posts
- Siavash Tehrani
- 732 posts
- mzigaib
- 996 posts
- mzigaib
- 996 posts
- moonlightkiss
- 156 posts
- mzigaib
- 996 posts
- circusmonkey
- 2624 posts
- mzigaib
- 996 posts
- circusmonkey
- 2624 posts
The motion blur is correct. The problem lies in the fact your geometry is moving large distances over single frames
ie frame 36 pipe breaks , frame 37 its moved over 4 meters ! Thats the equivalent speed of an electric nervous pulse !. Frame 38 moves back to start position 4 meters , frame 39 moves again 4 meters. Rendering that will give you one big blur !
r
r
Gone fishing
- mzigaib
- 996 posts
Thanks for the help.
What I think that´s strange is that even the piece of pipe that is not moving like the little piece in the middle top is receiving a weird motionb blur like a spike upwards, the motion blur should be given in a direction that the object is moving, the result that I am seeing is a spike of motion blur upwards, not in the direction that the pipe is moving or no moiton blur at all in the case of the pipe that is not vibrating. It´s like is bleeding to the wrong direction.
Agree?
Anyway thanks again for the help.
Agree?
- keyframe
- 1533 posts
I'll have to respectfully disagree with the previous assessment.
The motion blur is definitely off. try moving the trail sop INTO each branch – before your switch sops (the ones that switch between the broken branch, and the whole one).
What's happening in your shot is when you replace the whole geometry with the broken pieces, the point count changes… this makes things nasty for trail sop. It hates changing point counts.
G
G
- mzigaib
- 996 posts
- mzigaib
- 996 posts
