Bullet physics implementation and other stuff
301054 385 4- ilay7k
- 76 posts
- cybermax
- 255 posts
Bullet Update:
I implemented static animated geometry.
Its using for pushing objects - for eg. Earthquake = Road cracks going up and then down
https://vimeo.com/user3251535 [vimeo.com]
https://twitter.com/milansuk [twitter.com]
https://github.com/milansuk [github.com]
- cybermax
- 255 posts
I want to apologize to SESI, When I said that there is the plugin for voronoi fracture, so I dont understand why H11 includes this asset —>>> I tested it and new voronoi is very fast and accurate then original plugin!!!
I compiled source code for H11, so I think that H11 catch me :shock:
- cybermax
- 255 posts
I'm trying to optimize the process of loading objects and try to implements convex decomposition using multiple-threads. But no result.
When I write # include <pthread.h>, compiler says “file not found”.
I use VS2005 on 64bit Win7
Did someone similar problem???
- goldleaf
- 4170 posts
- Ratmann
- 110 posts
cybermax
Isn't pthread mainly a linux library? I know I had trouble with it when I was looking at it for windows.
http://sourceware.org/pthreads-win32/ [sourceware.org]
Think you might have to compile it yourself.
- johner
- 814 posts
cybermax
If this is a Houdini plugin, you might try the multi-threading support built into the HDK, which should work on any platform Houdini runs on.
http://www.sidefx.com/docs/hdk11.0/hdk_multithreading.html [sidefx.com]
- cybermax
- 255 posts
thx all
After hour I thought that pthread is for linux too. But I find some my old source code where I use multi-thread and for window its thread.h - but compiler write same error
So I will try HDK Thread from Johner links.
In this moment I simulate very big scene with fast response and low memory, but I must waiting over sending data from houdini to bullet(first frame), than Everything is fast(to the size of the scene)
- cybermax
- 255 posts
I have problems with Convex decomposition.
If I have two and more complicated concave objects close together I have problem with Convex decom which create a little bit different shape and bullet very fast push away this intersect objects.
So I decided write my own convex decomposition or there is any open source project with solved this problems????
- cybermax
- 255 posts
Solved … Smooooth …
- cybermax
- 255 posts
Second WIP video: http://vimeo.com/13988818 [vimeo.com]
Nothing special, no constraints, few bodies and In viewport you can see geometry for bullet collision. I will write code for applying transform data on original geometry, in this moment is not important :wink:
The reason for this test is new decomp system and its much more faster and I dont find any geometry “compression” so bullet return nice result (no explosions )
Ouu and finaly I jump to the H11, but within voronoi I havent tested another tool yet :?
- horizon1231
- 52 posts
- cybermax
- 255 posts
WIP pics
Frist floor with a lot of constraints.
Time per frame: 4-6s
One Cache file: 6,2MB(Bgeo)
Exterier Cam:
http://www.postimage.org/image.php?v=gxwqBor [postimage.org]
http://www.postimage.org/image.php?v=gxwqDTA [postimage.org]
http://www.postimage.org/image.php?v=gxwqGnJ [postimage.org]
http://www.postimage.org/image.php?v=gxwqLn0 [postimage.org]
Interier Cam:
http://www.postimage.org/image.php?v=gxwqrpS [postimage.org]
http://www.postimage.org/image.php?v=gxwqtV0 [postimage.org]
http://www.postimage.org/image.php?v=gxwqwp9 [postimage.org]
http://www.postimage.org/image.php?v=gxwqyUi [postimage.org]
This is still work in progress so some constraints still missing( for eg. roof with wall ) and boards on the floor is long(from one wall to other wall), but its fracture by voronoi.
Next problem its that I must test house with more max_forces(constraints) parameters because If I set big value, house dont break up, but with low value he break like a house of cards :?
I create HDK plugin for generating constraints and for example all board(the bigest geo in scene) compute in 1-2second, so its fast. :shock:
Exterier Cam:
Interier Cam:
- cybermax
- 255 posts
third WIP video: http://vimeo.com/14346567 [vimeo.com]
just more details and better house structure. With bullet plugin nothing changed :-). So version 1.0 is more and more closer.
There is still few bugs with setting max_forces(constraints), Its really difficult finding where every material have maximum force before breaking.
The most amazing thing is that if I hit play and I have all ground, The house dont breaks, so the all constraints working great and structure is right.
Objects: 2525
Constraints: 11731 :shock:
Time per frame: about 5s (substep: 10)
Cache files: 1.4GB(Bgeo)
Hell yees, 11731 constraints and its stable :!:
Objects: 2525
- CeeGee
- 216 posts
- fsimerey
- 279 posts
- cybermax
- 255 posts
CeeGee: nice test, before few months I working on this “type” of building with bullet DOP and I had similar result. Its want some constraints ( a lot of constraints :twisted: )
But problem is that I study and I must work on my bachelor work: http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=20518&start=0&postdays=0&postorder=asc&highlight= [sidefx.com]
I still working on bullet implementation, but in this moment My priority are in the muscle and skin toolkit.
I still waiting on Bullet 3.x.x with GPU fluids and OpenCL support. In this moment the plugin is not done I dont want to publish it for testing because It will have a lot of work with fixing your sending bugs and I must do some school stuff, so I dont have time for this. The next thing is documentation for bullet which I have to write for you :cry:
- cybermax
- 255 posts
ok, I make some progress.
I have few days free time. So I created example file with basic settings of plugin and now I finishing documentation so within few days waiting for first release of plugin.
I am sure that plugin will be compilated for win64, some days later win32.
Problem is that I dont have any experience with compiling under linux. I check that apprentice is for many Unix systems, so Have I compile for all this system??? And what about 32bit vs 64bit???
And I am sure that MacOS will not be supported because I dont have this OS in my HDD and I dont know anybody who has Mac. Sorry.
- Ratmann
- 110 posts
cybermax
Yeh, compiling for linux requires specific versions of gcc depending on what version of Houdini you use.
- fsimerey
- 279 posts
