FLIP fluids Viscosity?
12507 11 2- goldleaf
- 4177 posts
- Korhon
- 334 posts
- buki
- 1769 posts
and for friction too, seems that it has no effect
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
- jbudsberg
- 92 posts
- goldleaf
- 4177 posts
- Solitude
- 373 posts
I too am now wondering…
http://vimeo.com/14031860 [vimeo.com] << Flip is great… but would be cool to have the other options openly availalbe ( i'm wondering if they're still useable via the micro solvers )
Ian Farnsworth
- Solitude
- 373 posts
Surface Tension is a pretty easy one – can just connect ‘gas surface tension’ into the ‘volume velocity’ input on the flipsolver node and put vel, surface, and collision into the fields.
–still trying to figure out viscosity via the Gas SPH Forces… but I think it will require a bit more setup to get the data applied in the right places.
Ian Farnsworth
- tamte
- 8599 posts
Solitude
Can't you just plug Gas Blur or Gas Diffuse DOP into Volume Velocity input to blur vel field and tweak the parameters to?
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- niko3d
- 338 posts
The gas surface tension microsolver works a treat ;¬) Using the gas blur however doesnt really work as viscosity effect, as it messes with velocity as whole, i.e the effect of gravity etc is also dampened. Viscosity is more of an internal fluid friction/dampening. Not quite sure how we can get that to work.
Cheers
Nick
Cheers
Nick
- goldleaf
- 4177 posts
- niko3d
- 338 posts
- goldleaf
- 4177 posts
hmm…. I've got it plugged in there, but I'm not getting any changes to the sim. What do you have in the Velocity/Surface/Collision field parameters? Was you tension set really high?
**EDIT**
Nevermid, I forgot I hadn't looked at the included example file for the gas surface tension dop. It shows you need to have vel, surface, collision, respectively in the three fields I asked about.
thanks again!
**EDIT**
thanks again!
I'm o.d.d.
