hello
Is there a way to animate “use deforming geometry” option? I want objects to deform while they are inactive. Once they become active, I want objects to stop deforming. when I turn on “use deforming geometry”, objects deforms all the time and it affects simulation. so, I don't want deforming geometry to affect simulation. it seems that turning “use deforming geometry” on changes “hint_isgeometrydeforming” to 1. so I put modify data node to manually change this data, but it doesn't work.
I attached very simple test file.
a peace keeps getting bigger because of deforming. I want it to stop deforming while inactive objects keep deforming.
thanks
animate "use deforming geometry" ????
2246 2 1- eiji
- 16 posts
- tamte
- 8598 posts
maybe this thread can help
http://forums.odforce.net/index.php?/topic/17803-is-it-possible-to-activate-rdb-use-deforming-geometry-separately-for-each-obj/ [forums.odforce.net]
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- eiji
- 16 posts
