hi,
I render tiff format and the result is dark . I have to give a gamma 2.2 in aftereffects. Can I pre-bake 2.2 gamma in rendering?
thanks!
Render tiff use 2.2 gamma
3881 2 1- jerry7
- 621 posts
- PradeepBarua
- 443 posts
- tamte
- 8555 posts
to bake gamma into rendered frames you have to add vm_gamma property to mantra and set it to 2.2
its in (Edit Parameter Interface/For Rendering/Mantra/Output/Gamma)
however I don't recommend baking the gamma in renders unless they are just preview jpegs or something, but for use in further compositing deffinitely not
rather setup proper linear workflow in your AE so that the gamma correction will be applied automatically on your AE viewport
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
