Hey,
I have a bunch of curves with points and trying to get the start and end of each one.
i@neighbours = neighbours(0, @ptnum);
This gives me a list in an array with some with two values and some with one
etc…
how would I filter only the ones with 1 value in the array? Delete sop for example?
Filter neighbour array
2012 3 0- ludwigvon
- 27 posts
- animatrix_
- 4543 posts
You can use the neighbourcount function and group the ones that return 1.
- Andy_23
- 918 posts
you could also set the attribute wrangle to Primitives and run the following:
This gives you a primitive attribute for each curve containing an array with the start and end point numbers of that curve.
Hope this helps,
Andy
int i[] = primpoints(0,@primnum);
int start = i[0];
int end = i[len(i)-1];
i[]@start_end = {};
@start_end[0] = start;
@start_end[1] = end;
Hope this helps,
Andy
Edited by Andy_23 - June 29, 2016 08:45:14
- ludwigvon
- 27 posts
