Hi all.
I wondering is there any way to have multiple instances of an attribute vop network? It's important for me to update all the instances when the network of one of them changed.
Duplicate instance VOP Node
1744 5 0- Mohsen_Tabasi
- 53 posts
- Enivob
- 2572 posts
- Mohsen_Tabasi
- 53 posts
- mawi
- 242 posts
- tamte
- 8637 posts
HDA is the only way if you want the parameters to be instanced too (at least nowadays for CVEX, there still is an option to build old school SOP type vex nodes using VEX Builder Network )
otherwise you can also just use Attribute VOP and point to any CVEX shader so also to other Attrib VOP node, which includes Wrangles as they contain Attrib VOP inside, but again, the UI will not be mirrored so only useful if you want all of them to use your Master node's parameter values or not using any
also using HDAs has big advantage of being able to edit any of the instances and apply changes to the HDA definition which will be reflected in all instances using the same definition, also you can delete any of the instances without risking deleting your “master” node
so the only disadvantage of using HDAs would be that you have to unlock, edit, save and match instead of just edit live and have changes reflected, but on the other hand it's also safer that way
Edited by tamte - Feb. 2, 2020 19:07:02
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- Mohsen_Tabasi
- 53 posts
