I noticed that you are permitted to define a Material X shader in the /obj object context.
I'm creating an HDA in /obj, but want to render multiple instances of that HDA in LOPs, using Material X shaders.
I don't want to have to manually assign material X materials to each instance in /stage.
Is there a way to assign the Material X shader defined in /obj/MyHDA/matnet1 to geometry in /obj/MyHDA before it's imported into /stage Solaris?
Material X in /obj Context, Assigning in LOPs?
1013 2 1- jlapre
- 133 posts
- tamte
- 8618 posts
- syntheticperson
- 159 posts
