Implicit surfaces / extracting isosurfaces [[SOLVED]]
   415   3   1
Gang:
I’ve been playing around with implicit surfaces, using a Volume and a Volume Wrangle to define the surface function. Works great! However, when I use Convert Volume to extract an isosurface, I get a watertight “isovolume” instead (see attached) … is there an alternative method to get a true surface? Or a preferred way to create implicit surfaces?
Thanks in advance,
Tim
Edited by tshead - March 26, 2024 15:19:21
Screen Shot 2024-03-25 at 10.11.16 PM.png (3.5 MB)
use Convert SOP, you may need to adjust LOD UV or Divisions per span to 1,1
FX Supervisor
Method Studios, NY
Tomas:
Thanks, that did the trick!
Tim
Screen Shot 2024-03-26 at 1.18.33 PM.png (3.6 MB)
just set your LOD to 1,1 so that you use full res from your volume
Edited by tamte - March 26, 2024 15:35:55
FX Supervisor
Method Studios, NY
