I want to switch two object with “switch node”,for example,there is a sphere object node,an object merge node and a switch node in the scene,if there is no object in the merge node,the switch input is 0,else is 1,how to achieve this goal?I tried to write a expression code(as in the screenshot),but doesn't work,could you help me?Thanks in advanced!
How to switch via expression
10394 6 2- sunkjy2017
- 50 posts
- Nima
- 471 posts
Greeting.
You can use npoints function to get number of points in your object merge if it would be zero then it goes with sphere.
Documentation page for npoints:
http://www.sidefx.com/docs/houdini/expressions/npoints [www.sidefx.com]
for your file do this in switch1:
if(npoints(“../object_merge1/”) != 0, 1, 0)
- sunkjy2017
- 50 posts
- ninhenzo64
- 11 posts
- ddankhazi
- 8 posts
- animatrix_
- 4549 posts
You can also just do something like this:
npoints("../object_merge1/") > 0
- Mark Wallman
- 672 posts
Hi
I just found this thread.
There is also a new node to 18.0 called switchif.
https://www.sidefx.com/docs/houdini/nodes/sop/switchif.html [www.sidefx.com]
Best
Mark
Best
Mark
