List of local variable
553 4 0- metaclay2
- 48 posts
- Enivob
- 2572 posts
Here's some, but certain variables are only available on certain nodes in certain contexts. Check any node's help card for more details.
Scroll down a bit.
https://www.sidefx.com/docs/houdini/network/expressions.html [www.sidefx.com]
Scroll down a bit.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- metaclay2
- 48 posts
Enivob
Scroll down a bit.
Thanks a lot.
Btw , i found something else like D_X / D_Y / D_Z . Since we can't use it with '$' prefix then they're not variables ,right? what species is this other than variables and attributes ?
- tamte
- 8637 posts
metaclay2they are Constants, which represent more human readable alternative to just typing integer numbers
like in centroid() hscript function [www.sidefx.com], you can use
D_X, D_Y, D_Z
0, 1, 2
however for bbox() hscript function [www.sidefx.com], it may be much clearer to use:
D_XMIN, D_YMIN, D_ZMIN, D_XMAX, D_YMAX, D_ZMAX, D_XSIZE, D_YSIZE, D_ZSIZE
0, 1, 2, 3, 4, 5, 6, 7, 8
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- metaclay2
- 48 posts
tamtemetaclay2they are Constants, which represent more human readable alternative to just typing integer numbers
like in centroid() hscript function [www.sidefx.com], you can useinstead ofD_X, D_Y, D_Zwhich honestly is not that necessary and I always use 0, 1, 20, 1, 2
however for bbox() hscript function [www.sidefx.com], it may be much clearer to use:instead ofD_XMIN, D_YMIN, D_ZMIN, D_XMAX, D_YMAX, D_ZMAX, D_XSIZE, D_YSIZE, D_ZSIZE0, 1, 2, 3, 4, 5, 6, 7, 8
Thanks for the explanation. I really appreciate it.
