Hello Houdini community,
this is my first post, excuse my ignorance i'm super new to houdini, coming from cinema 4d background, watching "Stop being afraid of houdini" tutorial, the issue is that, the tutorial was made using houdini 18, while i'm using 20 indie, i found many changed nodes, such as the sweep in houdini 18, has three inputs, and the new one has only two ,
I was wondering if there is a topic/post talk about the differences between versions in that tutorial, if there is i would appreciate it if you could point me out to it,
if not, how do you usually tackle such an issue?
appreciate it.
watching "stop being afraid of houdini" sweep node issue
404 3 1- tenomotion
- 2 posts
- animatrix_
- 4516 posts
Unless the tutorial is updated, you have to figure it out for each case. You can also ask about it here for each issue you can't resolve.
youtube.com/@pragmaticvfx | patreon.com/animatrix | animatrix2k7.gumroad.com
- tamte
- 8555 posts
in a lot of cases when node changes drastically it's actually a new node type version
and you can revert to previous node type version [www.sidefx.com] and be able to follow tutorial
which is also the case with Sweep SOP
but then also this [www.sidefx.com] touches the topic a bit
Edited by tamte - March 29, 2024 12:36:19
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- tenomotion
- 2 posts
