$N broken in H15?
   3623   8   0
I have a Dop I/O node saving to disk a pyro sim and I am finding a very weird situation and wanted to see if it is just me not knowing or this is indeed a bug.
The node goes from frame 1 to 5 on .25 steps
When I save
blah.$F.bgeo -> it works as I expect and produces 5 files from 1 to 5
when I save
blah.$N.bgeo -> there is no number and creates and overwrites the file blah..bgeo again and again
Am I missing something?
thanks
CORRECTION, IT DOES NOT WORK EITHER ON MY MAC…
Strange because it seems to work on my Mac… the Windows box does not seem to be working… Will try updating the version and see.
Will keep you posted
Edited by jordibares - 2016年6月7日 05:43:12
オンライン
What are you expecting $N to evaluate to? I don't recall it ever being a variable.
オンライン
nvm, I looked up what it is here: http://archive.sidefx.com/docs/houdini14.0/expressions/_globals [archive.sidefx.com]
It seems to be working on OSX 15.5.480 after doing a simple test.
It does work on a regular output driver, $N gets evaluated as expected but it does not on a DOP i/o which I was kind of expecting.
The thing I am doing is oversampling the sequence (let's say steps steps of .25) and then output it as an integer so it will effectively be like a slow motion render.
mm…. well, I guess I will have to use $FF and then do it by hand.
オンライン
Ah yes, sorry I got confused.
Did it ever work with the DOP i/o, or is that what had just stopped working recently?
Just starting to use DOP I/O so first time really that i noticed.
jkunz07
Is DOP I/O an HDA? That can explain the lack of local variables support.
What if you use $FF ?
