Generate geometry at rendertime
   5637   3   1
How can i generate copies in rendertime of for example a box in a grid of points with the copy sop and with the Delayed Load procedural shader?
I tried a basic setup, two geometry generators; the one with the procedural shader calling a box from disk; the other with the basic copy setup, a grid connected to a copy sop and in the object to copy to a object merge referencing the generator with the procedural shader, but doesnt work this way, how can i archive this?
Thanks.
Please guys, help me, if anyone knows please share that knowledge.
Thanks.
See attached. Be sure to save out the teapot geo and point the shader to the correct file.
delayedload.hip (297.7 KB)
Thanks, but how can i control for example the scale of the teapods with this setup. i cant right? because the shader only calls that geo from disk but it cant modify the geometry? how can archive this i mean i need to control the geometry with the stamp() function but i need that all the copy geo are generated at render time, this way i can work with millions of faces.
