I have made a Python SOP at object level that sets up a few hundred nodes for later use in the animation.
I do not want this script to be ran every time I change the frame counter. Is there any way, except for changing the script to see if it already ran, I can control the cooking conditions, like only on change of a certain parameter?
Python cook only once.
8225 4 1-
- paleajed
- 20 posts
- オフライン
- graham
- 1926 posts
- オフライン
Your sop/object will recook every frame change if it is Time Dependent. If you MMB on the node it will tell you if it is dependent or not. If you make your python operator non time dependent it will not recook every frame change.
Accessing things like the frame number, animated parameters, fetching transforms or distances to nodes that are animated will all result it it becoming dependent.
- symek
- 1390 posts
- オフライン
paleajed
If I understand what you're after correctly, this is not a job for a PythonSOP. You can add simple Null object on /obj level, edit its definition, add a new script in Script Tab, and connect it via callback script with custom button added previously to a Null object. This is just one way to use custom scripts in Houdini and there are few others mentioned in HOM help page.
PythonSOP was meant to proceed geometry and it does cook every frame (I've never could make PythonSOP time independent like Graham suggested in other way then locking node or making some condition in python code. This could be handy option for sure.)
- edward
- 8080 posts
- オフライン
- symek
- 1390 posts
- オフライン
edwardSYmek
Well, there were a few bugs fixed in H9.5
How great! I've just checked and indeed it seems to cook only if needed in H9.5. I didn't know this was fixed ( I wasn't even considering it as a bug).
Thanks Edward (and Graham)!
