copy sop help
   3045   3   1
How to copy object to center of primitive and rotating along primitive normal? ops:
Create a point on center of every prim with the same normal attribute (I use a foreach in the example).
Maybe there's an easier way but… :
copysoporient.hip (66.5 KB)
With certain mesh topologies you can use the Divide node with everything but Compute Dual turned off. There are instances where this doesn't work, like a strip of polygons, so double check it to make sure your post-point count corresponds to your pre-prim count.
Jesse Erickson
Fx Animator
WDAS
nice example thank you very much.
