subnet (digital asset): more out connections
   2598   4   1
Hi ..
I searched a bit for this, but could not find anything yet.
I am creating a digital asset for SOP nodes.
In the DA, I am creating
1] geometry
2] polylines
that I need to grab again outside the DA.
How can I add a second output ?
Any input welcome !
matt
Hi Matt
You can only have a single out path on a node: Display node, which is also the first to cook.
A couple of obvious options here are:
1. Parametrize and/or group the separate data, merge it on it's way out and filter it in the next node.
2. Object Import the separate geometry & polyline branches to the nodes that need them (not dependent on the Display flag).
(all to the best of my experience anyway)
hi !
thanks for the inputs.
by the second option, you mean:
fetch the content of the last nodes (e.g. NULLS) from outside the DA, right ?
and the node name to do this is called ‘Object Import’ ?
matt
Yep that's right.
Object Merge's pointing to the NULL Sops that you want to import from your source DA.
great !
thankies !
:wink:
