Crowd with flares
   1922   4   1
Hi, i have single smoke flare sim, and i need somehow attach it to crowd agents, to be able randomly time shift smoke with agents. Any ideas will be appreciated, thanks!
Are you familiar with stamping in the copy stamp? You could use the stamp variables to make a random offset, then put a time shift after your smoke object merge and use an expression like this where “offset” is your stamped variable.
$F+stamp("../copy1", "offset", 0)
Edited by krueger - 2019年6月3日 14:44:29
mkps
Agree with you.
mkps
Thanks for reply. Sure i'm know stamping workflow, but i need exact same offset as in crowdsouce. Maybe transfer attribute from crowdsource?
Edited by Alex Kravtsov - 2019年6月4日 05:18:47
I haven't used crowds, but if there is an attribute you can transfer from the crowd source then you can use that in the copy stamp.
