Help with expression
3549 7 0- sanchoflat
- 26 posts
- asnowcappedromance
- 512 posts
well if you use the collision POP then you can tell it to output the “numhit” attribute. Which stores how many times each particle has collided with the ground. Then you group the collided particles with the following expression:
if($NUMHIT > 0, 1, 0).
Then you add a force POP (noise tab) or a curlnoise POP and tell it to apply the noise only to your newly created group!
cheers,
Manu
cheers,
Manu
- sanchoflat
- 26 posts
- ragupasta
- 349 posts
- sanchoflat
- 26 posts
- sanchoflat
- 26 posts
- sanchoflat
- 26 posts
- ragupasta
- 349 posts
$LIFE only works if the particle system know when that particle will die.
$AGE can be used as it comes along free with the particles, however if you want to actually see those values on a per particle basis, they are not inside the spreadsheet. You need to add a attribute in the popnetwork and create the $AGE variable. Once that has been done, you can look up those values in the spreadsheet.
