displacement shader not working
2163 2 1- kahuna031
- 897 posts
- rafaels
- 696 posts
It did work for me but only when I used that “Displacement Shader” parameter you exposed on the geometry obj.
I also tested creating a new geo container and object merging the geo from the first container and then applying your shader in the material slot and it worked fine. My guess is that by adding the “displacement shader” rendering parameter you bypass the material displacement capability.
Toronto - ON
- kahuna031
- 897 posts
