Arnold Question !
   7893   10   2
In the Maya , I can simply press texture button and assign texture to any parameter of the Arnold Standard shader , But I can't find this button in the Houdini Standard shader !
In this Arnold standard shader for Houdini , You should dive inside to your shader and append Texture node and connect it to any parameter that you like 8)
Rabiee.Sadjad@Gmail.Com
Just you should active input parameters for Arnold VEX node , because they are hidden by default :wink:
Really Thanks Sadjad
You are really Houdini Master :wink:
Jack.N
Your welcome my friend and really thanks ops:
Just one more question , I can render Old Particles with Arnold very well , But I can't render New Particles , It's show noting :?:
You should append Add SOP after your New-Particles , Then Turn On “Add Particle System” option in the particles section .
Yeah, only old particles are supported for now in HtoA, so you need to convert them, sorry for the inconvenience.
Frederic Servant / Solid Angle / London
www.solidangle.com
Does Arnold compatible with Houdini Indie?
Thank your Very much
Esteban
kikou
Yes , But that's not problem , Arnold is great forever 8)
nenuco
Esteban
Unfortunately no, Indie does not support 3rd party renderers.
www.solidangle.com
