Limit mantra cpu usage
   8250   6   2
I'm wondering if there is a way to limit the number of cpu that mantra uses.
When i limit it on windows via the task manager, it work, but only for the frame it is rendering when i do the manipulation. It's like if when it start a new frame it start a new processus so it uses automatically all the CPU cores.
I tried to google it but i didn't find any information about it.
thanks
http://voxelfx.fr [voxelfx.fr]
About windows we have different software for saving CPU Priority all time, for example you can search about Task Manager Pro .
However you can define number of CPU before rendering in the Mantra node –>Rendering–>Render–>Use Max Processor parameter.
NOTE : this problem is only for windows !
Rabiee.Sadjad@Gmail.Com
Thank you.
I also found that I could do it on the Mantra node > Driver tab > Command
by adding -j X at the end of the line. X representing the number of cpu used to render.
Prio is also good for persistent priority setting, for Windows; http://www.prnwatch.com/prio/ [prnwatch.com]
hi,
Take a look at this:
Mantra => Rendering => render=> Use Max Processors.
see the attached image.
@Joker386, sorry I didn't see that you mentioned that already :wink:
mor Mave
That's not problem man , I did too many wrongs like you :wink:
