Hi all, I'm writing an SOP that uses a third party library, which I link to. Now, when I load my plugin, I get:
Cannot load smoo.dll
Missing version information
When creating custom operators with the HDK ,remeber to
#include <UT/UT_DSOVersion.h>to define the required version information
I altered my PATH variable to include the directory with the DLL, but that error still comes up. Is there a way to link to a third party DLL?
cheers,
Easy3s
linking protocols for external libraries?
3302 4 1-
- easythrees
- 12 posts
- edward
- 8122 posts
- easythrees
- 12 posts
edward
Are you building with the correct compiler flags? Run “hcustom -d MyFile.C” to see the flags that should be used. Offhand, it looks like you're missing -DMAKING_DSO but if you're missing that, you're probably missing others as well.
These are the flags I'm using right now (line breaking for ease of reading):
—- SNIP —-
-TP -Zc:forScope
-DVERSION=“11.1.201”
-DI386
-DWIN32
-DSWAP_BITFIELDS
-D_WIN32_WINNT=0x0501
-DWINVER=0x0501
-MD
-EHsc
-GR
-DSESI_LITTLE_ENDIAN
-DNEED_SPECIALIZATION_STORAGE
-DSIZEOF_VOID_P=4
-DMAKING_DSO
—- SNIP —-
I do have MAKING_DSO specified. I should note that ‘smoo.dll’ is the third party DLL (I had copied it over to where my SOP's DLL is loading from).
- easythrees
- 12 posts
easythreesedward
—- SNIP —-
-TP -Zc:forScope
-DI386
-DWIN32
-DSWAP_BITFIELDS
-DWINVER=0x0501
-MD
-EHsc
-GR
-DSIZEOF_VOID_P=4
-DMAKING_DSO
—- SNIP —-
I *think* I know why this is happening. The link in proper seems to only happen in release mode. When I switch to release mode (and use the specified flags), I get no error messages. Onward!
- AlexLombardi
- 30 posts
resurrecting an old thread (That saved me
)… I was finally able to compile the sop_star example using visual studio 2015. What really through me off was not including -DMAKING_DSO in the command line on my project settings.
My question is why doesn't -DMAKING_DSO show up in the needed flags when using hcustom -c ?
hcustom -d “myFIle.cpp” will out put the exact same just with a -DMAKING_DSO -LD -Fo“myFIle.o”
I'm just a little confused what the difference between -d and -c are in hcustom.
Alex
)… I was finally able to compile the sop_star example using visual studio 2015. What really through me off was not including -DMAKING_DSO in the command line on my project settings. My question is why doesn't -DMAKING_DSO show up in the needed flags when using hcustom -c ?
Alex
Edited by AlexLombardi - 2016年8月16日 18:16:42
