Hello out there.
I downloaded the Aprentice Version.. 4 days ago. Worked fine till today. now it Houdini Simply will not open. It goes througth the checking for server but doesn't find one. Then the installer asks me to install the licence server again.. that is successful, then the installer checks for the lic over the net again unsucessful… and then back it starts over again.
I have uninstalled houdini and restated. Now I will try to reset my modem.. Ugg..
Any suggestions?
aurafx@aol.com
More LIC problems..
6643 6 1-
- aurafx
- 16 posts
- stevenong
- 1634 posts
- aurafx
- 16 posts
steven
here it is. thanks for looking in to this.
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Thu Mar 13 19:19:19 2003
Local host name: SUBZERO2
Local server code: 0df87377
Local ip address: 127.0.0.1
License server name: subzero2
License server server code: 0df87377
Server ip address: 127.0.0.1
License server is running: Yes
Has SERVER license: Yes
License server version: 5.5.208
May modify server from this machine: Yes
License Administrator version: 5.5.208
Http proxy host: (none)
Using standalone mode: Yes
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
4d13d0d7 Generic Houdini-Master-NonCommercial 5.5 0/0 11-mar-2003
=== This license has expired ===
c6e59f96 Generic Render-NonCommercial 5.5 0/0 11-mar-2003
6d8c916b Generic Houdini-Select-NonCommercial 5.5 0/0 11-mar-2003
18aa814f Generic Houdini-Escape-NonCommercial 5.5 0/0 11-mar-2003
sesictrl -i output:
—– SERVER subzero2 ——–
Lic 4d13d0d7: 0 “Houdini-Master-NonCommercial 5.5” Generic 11-mar-2003 +.+.+.+
Lic c6e59f96: 0 “Render-NonCommercial 5.5” Generic 11-mar-2003 +.+.+.+
Lic 6d8c916b: 0 “Houdini-Select-NonCommercial 5.5” Generic 11-mar-2003 +.+.+.+
Lic 18aa814f: 0 “Houdini-Escape-NonCommercial 5.5” Generic 11-mar-2003 +.+.+.+
hserver -l output:
Hostname: SUBZERO2
Uptime: 2:55:06
License Server: subzero2
Server Version: sesinetd5.5.208
Version: Houdini5.5.208
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
724 of 1023 Mb available
CPU Usage: 5% load
0 active tasks (2 slots)
licenses file:
## Side Effects Software License File
# For license information, please contact:
# Side Effects Software Inc.
# 477 Richmond St. West, Suite 1001
# Toronto, Ontario, Canada
# M5V 3E7
# licensemanager@sidefx.com
# http://www.sidefx.com [sidefx.com]
# NOTE: This file may be modified by the licensee
# Key installed 11:36:58 02/07/03
SERVER subzero2 0df87377 e105ae9ec1da9cab33059dc3c2c7f062ad85bff863ed32
# Key installed 11:37:00 02/07/03
LICENSE Generic Render-NonCommercial 5.5 1 11-mar-2003 +.+.+.+ subzero2 \
c6e59f96 375b28f01f22ca128ed7550c0fcfc1897398119b0dcde
# Key installed 11:37:02 02/07/03
LICENSE Generic Houdini-Escape-NonCommercial 5.5 1 11-mar-2003 +.+.+.+ \
subzero2 18aa814f 447bb84dcf74585ccbdaf00aeb4746f0c4c33f4722709
# Key installed 12:31:28 02/07/03
LICENSE Generic Houdini-Master-NonCommercial 5.5 1 11-mar-2003 +.+.+.+ \
subzero2 4d13d0d7 e2537fa385d8c4ad4da7e42a3a86334cf669137360a8c
# Key installed 15:20:58 02/08/03
LICENSE Generic Houdini-Select-NonCommercial 5.5 1 11-mar-2003 +.+.+.+ \
subzero2 6d8c916b 049f8931b1716a48594e2be2eb5083f434c0749fa2b91
Diagnostic Output:
Installed licenses:
sesictrl -i output:
hserver -l output:
Hostname: SUBZERO2
Uptime: 2:55:06
ReadAccess: +.+.+.*
CPU Usage: 5% load
licenses file:
# M5V 3E7
TAP TAP Umm is this thing on?
- stevenong
- 1634 posts
Hi there,
The date on your machine is currently set to March 13 which caused your licenses to expire.
Please correct the date & then try running Houdini. If it still does not run, please start the License Administrator then Right-Click on the license string & select “Return License”. Please return all licenses you have then quit the License Administrator.
Now, start Houdini & you should be prompted to install Apprentice Licenses.
I hope the above helps!
Cheers!
steven
Cheers!
steven
- edward
- 8076 posts
- TL
- 10 posts
- aurafx
- 16 posts
