We are having issues with tiled renders not writing out the images planes that are present in scene. Doing a local render or non-tiled submission with Afanasy works as expected.
Looking at the tile renders generatedby the job before the stitch, it appears that whilst there is a separate .exrfile written out for every tile named “filename.exr.tile_1.exr” for example for tile #1, this contains no image plane information. We also have a file namedsimply “filename.exr” which does have embedded image planes but seems to be being written to by each node that is rendering a tile, simultaneously and is always unreadable.
Is this correct behaviour and does Afanasy actually support tiled rendering with image planes in Houdini? I would have thought that each separate tile .exr would contain all of the required image planes for the stitched image.
If you can shed any light on what we may be doing incorrectly that would be appreciated.
thanks
Tom
Houdini tiled rendering problems with Image Planes
4644 6 2-
- interferencepattern
- 6 posts
- dlee
- 471 posts
- IP_Animation
- 8 posts
Hi, Thanks for your reply. It's actually the extra image planes within the same file as the beauty that we are having problems with. Essentially at the end of the stitch we just get a beauty plane and nothing else in the final stitched render. The component tile .exr's also contain only the beauty plane. The image planes appear to be being written to an .exr that has no tile number suffix. This gets overwritten by each node as it renders it's assigned tile, rendering it redundant as the tile planes for each image are lost. It possibly appears as if the filename defined internally for the image planes does not get the “tile” suffix added and so these are being written to a file that has the final filename (without tile number suffix)?
I've attached a screengrab of the files I get out of a test submission, before the stitch. The straight .exr without tile suffix gets accessed and overwritten as each node completes it's tile. So the .exr's with tile suffix are what we should be getting in terms of file naming, for Afanasy to do the stitch automatically, just without any embedded image planes within.
For our actual submission we have 400 tiles, so manually joining is not an option.
thanks
thanks
- dlee
- 471 posts
- IP_Animation
- 8 posts
Yeah, that's right. If everything was working as expected then it should initially create only the files with the tile suffix, which would contain all image planes, and then merge into the single final .exr afterwards. I've posted on the Afanasy forum but thought I'd drop here as well in case someone had come across a similar behaviour.
- IP_Animation
- 8 posts
- TimurH
- 17 posts
Hi.
The next Afanasy release will use Houdini native itilestitch tool. Bug will gone (tested).
https://cgru.readthedocs.io/en/latest/software/houdini.html#tile-render [cgru.readthedocs.io]
Edited by TimurH - 2020年9月2日 05:05:34
