FLIP fluid volume
   3403   4   1
Hey guys,
Trying to figure out if there is a way to “cheat” filling a volume faster with FLIP fluids.
I have a glass that I am pouring liquid into and I feel like the rate at which it is filling my volume is accurate, im just wondering if there's a way to speed it up, basically I'd like to cheating the volume of the fluid a little bit. If I remember correctly, in Real Flow for example if you increased internal pressure the particles would “take up more space” in the glass.
Thoughts?
Christian
christianhjohansson
Hey guys,
Thoughts?
Christian
Divergence is your friend!!
http://forums.odforce.net/topic/30874-flip-and-divergence/?tab=comments#comment-172220 [forums.odforce.net]
http://forums.odforce.net/topic/29796-flip-pouring-into-closed-container/?page=2&tab=comments#comment-167980 [forums.odforce.net]
Cheers!
Alejandro
Edited by Alejandro Echeverry - 2018年6月15日 14:16:59
Aha, thanks Alejandro, a nudge in the right direction was all i needed. Will explore this.
Cheers.
Hey,
So I am checking “Add Divergence Field” in the Flip Fluid Object and also checking “Divergence by Attribute” in the Flip Solver and set the Divergence Scale to 2000 (just to troubleshoot), however I get this error message on the Flip Solver:
Warning
update_divergence_field:
Warning: flipfluidobject - /obj/AutoDopNetwork/flipsolver1/update_divergence_field: Required attribute divergence is missing.
What is the attribute that is missing?
Ah. Solved by adding pop wrangle and adding “@divergence = 0.8;” to it.
Edited by christianjohansson - 2018年6月16日 08:06:27
