Hello everyone,
I am experimenting with wire deformer sop. I animated a line with a sine wave and deformed a snake geo with it. Now, the main problem i have is that there is a regular twitch (it can be seen better in wireframe mode ) that supposedly comes from the animation but i can't figure out how to eliminate it. Any ideas?
Many thanks
Francesco
Wire Deformation Twitch
1249 2 1- ProceduralFrankie
- 76 posts
- Mohanpugaz
- 132 posts
Had a look at your file.
It has few things to fix.
That it your snake wont have those weird twitch.
Thanks let me know if this helps
- do not resample the curve after the point sop animation. (tip : use blendshapes sop to create a pose to match the snake pose after you point sop)
- the point count on the rest and deforming ideally should be equal.
- on your wire deform node > blending > set this to Biased or weighted
Edited by Mohanpugaz - 2018年12月20日 09:10:36
Mohan Pugaz
movfx
movfx
- ProceduralFrankie
- 76 posts
