The problem is “print” node in Mat could not return the value(the console will not pop up).
Here I have 2 files which have exactly the same nodes.
The file A is from the Internet where other people use “print” node and it works well. I delete all his nodes and create some other nodes to make things easier to understand.
The “print” node could return the right value in console while rendering.
So I create a file B and do exactly the same thing. But the console just won't pop up when I start render.
By the way, the console will not pop up either if I use non-commercial houdini to open file A.
I really have no idea about why that happens.
Thanks for any clue.
problem about "print" node in mat
1090 2 2- fengshuochange
- 16 posts
- bonsak
- 459 posts
- fengshuochange
- 16 posts
