HI i dont know why , but if i try to render this project whit my farm i have this error message.
Other project no problem
The Houdini 18.0.348 environment has been initialized.
File “/opt/hfs18.0.348/houdini/scripts/hqueue/hqlib.py”, line 1550, in main
function(**kwargs)
File “/opt/hfs18.0.348/houdini/scripts/hqueue/hqlib.py”, line 480, in submitMultipleRenderJobs
hq.houdini.loadHipFile(hip_file)
File “/opt/hfs18.0.348/houdini/python2.7libs/hqueue/houdini.py”, line 22, in loadHipFile
hq.utils.logInfo(“Loading .hip file %s.” % hip_file)
File “/opt/hfs18.0.348/houdini/python2.7libs/hqueue/utils.py”, line 31, in logInfo
sys.stdout.write(“%s\n” % msg)
UnicodeEncodeError: ‘ascii’ codec can't encode character u'\xe8' in position 61: ordinal not in range(1
Render farm problem 18.0.348 just in one project
1934 6 3- bgood
- 141 posts
- PJM33
- 15 posts
what software are you using for you farm? Deadline?
What's in your farm?
Pierre-James
pierrejamesart.com
pierrejamesart.com
- bgood
- 141 posts
- PJM33
- 15 posts
hqueue has a bad reputation. Deadline is really well liked and usually works well
Pierre-James
pierrejamesart.com
pierrejamesart.com
- bgood
- 141 posts
- rvinluan
- 1256 posts
bgood
function(**kwargs)
I believe that the error has to do with the .hip file's name and/or folder path. HQueue uses ascii for most things in jobs and unfortunately does not play well with certain characters in file names and folder names.
Is there a non-ascii character in the .hip file name? If there is, then try renaming the file and see if that helps.
Rob
- bgood
- 141 posts
